Cam shaft oil seal
kelvingenders
Cam shaft oil seal
Post by kelvingenders »
Anyone got ideas of this can be achieved easily. :360: for a b200 engine
Re: Cam shaft oil seal
This the part you are looking for?
http://www.classicswede.co.uk/B19_B21_B ... 36492.aspx
and if you needed the tool to fit it with
http://www.classicswede.co.uk/9995025_B ... 27249.aspx
I suspect postage back and forth would make the tool expensive to borrow but you can improvise with fitting the oil seal
Do you really need the tool? I've never used it, just push it in with fingers and flat bar.
Its a pretty standard seal, should be available from a bearing vendor.
