rev limiter ??
skd360
rev limiter ??
Post by skd360 »
Hey guys I've got a1986 Volvo 360 glt with the b20 injected and I doesn't have a limiter to my knowledge revs past 7 just wondering if they ever came with them and what my options are as to installing one
Nimminz
Re: rev limiter ??
Post by Nimminz »
You can get an OMEX rev limiter for about £80 - £90 which just simply wires to either side of the coil and an earth, you set what RPM you want it to limit at and choose between 'soft' and 'hard' limit. You can also get the same one with shift lights or launch control for a few quid more. Mine used to shoot flames ...
http://www.youtube.com/watch?v=lLMIHgjzPnQ
Re: rev limiter ??
Some of the renix units have electronic limiters. The B19's tended to use a centrifugal spring thing on the disty rotor arm.
I'm not 100% sure but would expect an 86 B200 to have an electronic limit.
skd360
Re: rev limiter ??
Post by skd360 »
Nimminz wrote:You can get an OMEX rev limiter for about £80 - £90 which just simply wires to either side of the coil and an earth, you set what RPM you want it to limit at and choose between 'soft' and 'hard' limit. You can also get the same one with shift lights or launch control for a few quid more. Mine used to shoot flames ...
I've looked around cheapest one I've found is like 200 and ice it converts to ausd it's like 400
Re: rev limiter ??
You have a good thing there with no sill rev limiter and you want to spoil that?
I would normally be pulling any rev limiter off
Logan360
Re: rev limiter ??
Post by Logan360 »
Looked into a bee.r rev limiter?not sure if they will fit but there quite common over here in the D1NZ cars and the like.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
skd360
Re: rev limiter ??
Post by skd360 »
classicswede wrote:You have a good thing there with no sill rev limiter and you want to spoil that?
What's good about no rev limiter dai ?
Logan360
Re: rev limiter ??
Post by Logan360 »
High rpm for maximum skidness
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: rev limiter ??
The engine is safe to rev all the way to valve bounce if you can get it that far so no danger of over revving.
No rev limit makes over taking safer etc as you can take the revs a little higher if need be rather wasting time with a gear change.
Rev limiters cause backfires on LPG
The biggest reason for modern engines having a rev limit is more about making sure the fuel injectors do not reach maximum duty cycle.
Rev limiters also make a horrible sound
