going to be converting my 360 to twin webbers but need advice on what to do about ignition. can I still use the renix? or is it possible to remove and replace with an aftermarket ignition system? eg omex megasquirt etc. and if so what exactly is involved
HELP! twin carbs ignition
Re: HELP! twin carbs ignition
If this the only mod I don't think you will exceed the ignition map. Ignition more depends on cam, compression, octane.
I plan on fitting a cam in the future and possibly head work as and when I get money so ideally want something that would get the most out of those mods. hence why I figure an aftermarket mappable ignition system would be the best route?
123 ignition do a bolt in programmable distributor or you could fit something like megajolt
- volvodspec
so if you feel comfortable about megasquirt and the others mentioned, why not skip Webers and go for a ITB setup?
Full engine management is generally 3-4x the price of ign only
Already have the carbs and the manifold. Just trying to find out if I can run the standard ignition set up or if I'll need to change it.volvodspec wrote:so if you feel comfortable about megasquirt and the others mentioned, why not skip Webers and go for a ITB setup?
Will have a look at that 123 ignition cheersclassicswede wrote:123 ignition do a bolt in programmable distributor or you could fit something like megajolt
Webers are cooler!volvodspec wrote:so if you feel comfortable about megasquirt and the others mentioned, why not skip Webers and go for a ITB setup?
1984 Volvo 360 GLE Saloon
1987 Volvo 340 1.7GL
Additionally -
1966 Ford MK1 Cortina
1971 Hillman Imp
1984 Renault 18 GTD
Additionally -
1971 Hillman Imp
1984 Renault 18 GTD
