Removal of b200 engine mounts
kelvingenders
Post by kelvingenders »
Hi guys, how can you tell if engine mounts on a B200 are knackered. Also, how can these be removed safely without dropping the engine on the floor? :360:
Re: Removal of b200 engine mounts
Post by bogbasic »
Its got a pretty strong sump so I have supported it on blocks of wood - I thinks it should be OK if you leave the bell-housing and torque tube attached, but others will know for sure.
Logan360
Post by Logan360 »
I has done this 6 tines. Basically you should be able to get at least your finger tips between sump and cross member. If your sump is on your cross member and there's no gap, they are shot.
Removal.
I crack both nuts before I do anything else.
Jack sump up till jack takes some engine load, or till you see car move gently.
Undo nuts on Mount completely
Then I remove the top bracket and pull mounts straight out.
Exhaust side is harder as exhaust is in way. Top bracket does still come out but bottom brscket removal may be easier.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
