Hello,
I need the right rear driveshaft (also called "half shaft", the shaft between the diff/tran. and the wheel) with both joints (wheel side & tranny side) for Volvo 360 B200K '87.
Also, does anyone know, are they the same as for 340?
I need it urgently, will pay for DHL shipping, as this is the only thing left that i need to get the car on the road again.
thanks
Rear wheel driveshaft with joints Volvo 360 '87
87 360GL B200K
half shafts
inner and outer cv joints are the same.
you can put a joint from 1978 model to 1988 model.
not sure about shaft length.
left and right ones are the same too. usually the outer joint of right shaft goes out first - you cannot see broken boot at once.
I guess the previous owner did. I thought only the joint needs to be replaced, but my mechanic said the shaft is also bad.Janitor wrote:be carefull-shafts the same BUT diff's are different! depending on what g'box you have. you may have to put a spacer between diff output and the driveshaft.
did u snap/bend a shaft?
But it seems I got extremely lucky today. I found exactly the same model car at a local scrapyard which is a miracle because 360s are almost non-existent here. The guy said the shafts & joints are still good and the boots aren't broken. I'll go get them tomorrow.
87 360GL B200K
are cars in your scrappys not stacked? over here its a nightmare trying to get somethign off the bottom of a scrapped car.
Re: shafts
I dismantled it completely.mgarageu wrote:i do not agree completely. have replaced or repaired these on several 300-s. shaft diameter does not matter. how can you see actual shaft length without dismantling it completely?
87 360GL B200K
