wheel stud sizes
Turbosled
wheel stud sizes
Post by Turbosled »
Hi all,
Bought a set of minilights for the 340, however, the studs are a bit too short
does anyone know the thread details and length of the original ones so i can find somw a bit longer?
I know asking is a bit lazy, but i really dont wanna head outside in the pouring rain to whip a wheel off :lol:
cheers guys
thododd
Re: wheel stud sizes
Post by thododd »
Not sure on overalll length but theyre m12x1.25
Turbosled wrote:I know asking is a bit lazy, but i really dont wanna head outside in the pouring rain to whip a wheel off :lol:
A bit lazy? Gertcha arse out there! :lol:
It is lazy, because although the info is still in the "to sort" pile and not accessible, there is a cached copy on Google ;) so no need for any bellyaching about a bit of water from the sky.
Adam "340GLT" said back in Feb 2011:
Hi mate standard overall stud length is 43.5mm. You won't find a direct replacment in a longer length. Get from grayston 12x1.25 thread diameter with the 14.3mm spline diameter. Drill hub to 14mm and use a machined tube and nut to pull them through.
Link to cached topic
Joris
Post by Joris »
Subaru Impreza studs are widely available on ebay, and fit if you drill the holes to 14mm
TheUglyDuckling
Post by TheUglyDuckling »
I'd rather not drill the holes. Does anyone know the diameter of the original wheel studs? I have found a supplier for 12,8 and 13,0 (and 14,2 and 14,3).
Joris
Post by Joris »
TheUglyDuckling wrote:I'd rather not drill the holes. Does anyone know the diameter of the original wheel studs? I have found a supplier for 12,8 and 13,0 (and 14,2 and 14,3).
I was sceptical at first about drilling, but when you put the hub under a pillar drill it goes right through and getting the new ones in is easy. Just take some time and pull them in slowely which some cutting oil and and old wheel nut.
