Rubber floor mats
S10NPH
Rubber floor mats
Post by S10NPH »
Hi
I am looking for a set of 4 rubber floor mats for early 343s, they are soft plastic/rubber, rather than the later hard tray type. They look like this:
Brown ones would be perfect, but as I am realistic, black is also fine.
Thanks
Siôn
Re: Rubber floor mats
Post by Hell Driver »
Can't see anything there!
Edit.......... now I can, not sure what happened!
I've never seen those before.
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
I have and they fall to bits. Good luck Sîon!
Post by MCHUDD »
Hi Sion.
If you have no luck with those , i have a perfect
set of trays you can have.
sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4
S10NPH
Post by S10NPH »
Hell Driver wrote: I've never seen those before.
I have a full set of them in both my 1979:
and my 1980:
Both cars came with them when I bought them.
The Volvo 343 in the Volvo museum in Gothenburg has the brown ones:
MCHUDD wrote:If you have no luck with those , i have a perfect
I think the trays are a slightly different shape, so wouldn't fit properly in the front footwells. I have tried the ones I have in my 1985 car into the '77, and they don't sit flat onto the floor.
The difference is in the inner corners. Later ones have a bit "cut-off" to make way for the heater pipes to the rear.
Yep macplaxton is right... you can get floortrays between 80-82 that'll fit, they have an angled corner as opposed to being straight both sides :)
