F7p conversion
F7p conversion
I have got a 340 with f7p engine conversion could anybody help me on how to adjust idle speed please
Re: F7p conversion
what fuel system is it running?
Re: F7p conversion
The standard injection system with ecu
- Alex Laidlaw
Re: F7p conversion
There's no adjustment of idle speed, it should idle correctly if everything is present and correct. What is it actually doing?
Re: F7p conversion
Could be a number of things. First thing I would check is that the idle air control valve takes it's air from the main feed to the throttle body, not a separate filter. It has to have some vacuum on that feed.
Re: F7p conversion
Ok thanks will try that first
driftking89
Re: F7p conversion
does it drop below what you state is fast idle if it does then while engine is running pull one plug off at a time round the throttle housing if there is a change in engine behaviour this means that the sensor is working so try that its quicker
Volvo 340 2.0 Supercharged drift wagon
Volvo 850R 2.3 Turbo
Toyota Celica 2.0 Import
