hybrid clutch issues..
Posted: 01 Jul 2014 08:34 pm
Hi all,
I need to call on your technical knowledge (or the previous owners of this car)
to start the story, I am the new (be it a year) owner of trundle 2.
now this car had undergone a b18ft conversion at some point in its life, and the time has come to replace its clutch.
being a conversion this isn't so simple (as I have found out after purchasing an "uprated" clutch from ebay)
ive purchased a stage 2 uprated Volvo 480 turbo clutch, and have found this unsuitable for the flywheel or bellhousing.
so ill present you with the facts I already have at my disposal:
the input shaft of the bell housing (that the clutch mounts to) is a 1.7 20 spline.
the flywheel is what I believe to be the original 480t item. (7 bolt crank fixture, 6 bolt clutch fixture) and has a part number of stamped on it of, DA 088381 5
pressure plate that was removed from the car is stamped as valeo, and I cant find a part number.
friction plate that was removed from the car is stamped as " 168-2 , 131-3, q made in the uk"
im at a bit of a loose end.
I suspect the centre plate to be a 1.7 Volvo item, although the pressure plate has me stumped.
the idea was to purchase the uprated item, although I feel that this hybrids going to cause a few issues.
if anyone could shed some light on this I would be greatfull.
further investigation using this link:
http://www.volvo-480-europe.org/volvo48 ... 3ELC549404
I think my engine is from a 1990 440 turbo. (my engine plate reads: b18ft 107 C054947)
06 = B18FT(M)-107
C = NedCar, Born (Netherlands)
549001 - 563101 = 1990
thanks
madseb.
06 = B18FT(M)-107
thanks
madseb.
