fitting voltmeter into gauge cluster
Does anybody know if it would be possible to fit the VDO 2/300 series voltmeter into the gauge cluster where the economy gauge goes?
Re: fitting voltmeter into gauge cluster
I'd imagine it'd be easier to put a 400 series one in there and move the pin across from a 300 temp or fuel to make them match? I've never tried either mind.
I thought about using a 400 series but I don't like the look of them.
It's al possible, you just have to make it fit.
This is with a 440 oil pressure gauge.
This is with the shift indicator moved to the right side.
I think this is the best solution, almost like it's ment to be there. And available in different specs (oil, turbo, volt, etc.)
I should have said the only place for it to go is the economy gauge slot
I've got an OEM 300 series VDO oil pressure gauge and 240 turbo gauge to go in the centre console (just waiting for Logan360 to make fibreglass replicas)
I think the 400 series gauges don't suit the rest of the 300 series and I can find plenty of 2/300 series VDO voltmeters for sale and if I can't afford them from America then VDO sell new gauges that look very similar for sensible prices.
But you have answered my question Joris thank you
THAT SHIFT LIGHT ONE!!!! that is exactly what I want to do. is there a write up? also re replicas just waiting on finding good enough clay to make flawless replicas.
Own:
86 360GLT
97 S90
92 960S, Royal
01 Subaru Lancaster 6
96 Volvo 854R
Owned
E90 320 M-sport wagon
S60T -Mazda Familia
850lpt -AU Falcon
855T5 -91, 95, 97 960
940TIC -Mitsi GTO TT
16x 360-Toyota corolla
Toyota corona-R32 Skyline
V70R -V70T5
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
The BMR 360 has 50mm Volvo 240 gauges.
About the shiftlight, They are only fitted to 360's with the b200k (2 liter carb.) engine. And are controlled by some black box next to the left topmount in the enginebay. I've tried to get it working with the LH 2.4 injection system because the ECU has the connection for the shift light, but that didn't work. You need some rare Volvo 240 relay and throttle position switch if I'm right.
shiftlight is controlled by the Renix, not by the black box lh side of engine bay; that's purely fuelcutoff system
That's what I want to do, except remove the casing from the gauge so it sits flush like the rest of the gauges.Joris wrote:The BMR 360 has 50mm Volvo 240 gauges.
yea a mate is pulling all the shift light parts out for me. was just wondering if there was a fitting writs up
Own:
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
I will scan a page Mac sent me about the shift light and upload it.
Hi all.
I have removed my ashtray and put another one in there
turns out my ideas aren't so orignal after all. I'm getting a fiberglass pod made for a boost gauge for the ashtray hole.
Own:
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
86 360GLT
97 S90
92 960S, Royal
96 Volvo 854R
Owned
S60T -Mazda Familia
850lpt -AU Falcon
V70R -V70T5
Did you use the bezel from a 240 VDO gauge?MCHUDD wrote:Hi all.
I have removed my ashtray and put another one in there![]()
Cheers Mark.![]()
Hi beast.
Yes mate. Widened the centre a little. Had to put a hole at the back
of the ash tray hole to bring the wireing in. Wired it to the ignition
so as not to drain the battery and the light bulb to the light switch.
