volvo 340 engine conversion 440 engine
driftingmonkey
Post by driftingmonkey »
hello ! I have a Volvo 340 with intentions of putting a Volvo 440 1.7 turbo engine into it what gear box and diff would/could I use ? HELP
360beast
Re: volvo 340 engine conversion 440 engine
Post by 360beast »
Standard gearbox and diff, if it's for drifting then weld the diff.
Just make sure you have good engine mounts and the propshaft is aligned or you will snap the propshaft.
Should fit right on the 340 clutch housing but I think you need a pilot bearing.
Rubenv340
Post by Rubenv340 »
How do you, in fact, check the prop alignment?
360beast
Post by 360beast »
Rent the laser alignment tool from Dai
