5 speed gearbox paper gasket
derskine
Post by derskine »
Anyone know where I can get the paper gasket that goes between the gearbox and diff?
It's for a 5 speed.
Or do I need to make one?
1984 Volvo 360 GLE Saloon
1987 Volvo 340 1.7GL
Additionally -
1966 Ford MK1 Cortina
1971 Hillman Imp
1984 Renault 18 GTD
Re: 5 speed gearbox paper gasket
Post by MCHUDD »
Didn't mac used to do them.
Not shure if he is about at the minute.
sm4 sm4 sm4 sm4
Mac / RJ / Dai should have one.
See here: viewtopic.php?f=8&t=14883&p=175599
Macs kit is for the diff cover not the diff-gearbox one.
Have you tried Volvo? This might be the only part that isn't NLA. Get the pn first.
tralla44
Post by tralla44 »
Make you self that paper gasket..
when i build my lsd i was making diff gasket and from diff to gearbos gasket + grease where no need a gasket.. ;)
Ride to Live
Live to Ride
tralla44
Post by tralla44 »
tralla44 wrote:Make you self that paper gasket..
Iwas making from bosch old air filter box
Ride to Live
Live to Ride
derskine
Post by derskine »
Fair enough, will get some gasket paper and make one.
I've used an old bosch parts box before though!
It's not urgent, but theres a bit of oil leaking out and I'm unsure if this is leading to a noise that sounds like an angry turkey sometimes when in 2nd + 3rd gear.
Additionally -
1971 Hillman Imp
1984 Renault 18 GTD
It may not be a problem in the 5 speed but the 4 speed is very dependant on the gearbox gasket thickness, only the exact material spec will do. Anything else will need the compressed thickness calculated and measured for shim adjustment as in Haynes but more complex. It controls the bearing preload.
