injectors
Posted: 25 Jun 2015 08:57 am
by 360beast
I'm thinking of swapping in the head and block from my B230ET while my 360 is in restoration mode.
I would be swapping over the engine mounts and inlet manifold and keeping it N/A for the moment. What do I do about the size of the injectors? Will the B200E ones be fine or do I use the ones from the B230ET?
Re: injectors
Posted: 25 Jun 2015 08:03 pm
I'd go with the originals, they are matched to amm and controller, they fuel system only has a Max bhp and doesn't really care what size the engine is. I would expect the B200E should be fine with the small increase.
I would be more worried about ignition timing, changing CR or cam will change the burn characteristic. However there are many Renix units to chose from.
Re: injectors
Posted: 26 Jun 2015 06:58 am
by 360beast
Thanks Ride_on, the cam will still be an A cam as that's what the 531 head comes with on the ET.
How much power and torque am I looking at gaining from the B230? I'm not really doing it for this mainly just to make life easier when I fit the turbo stuff.
Re: injectors
Posted: 26 Jun 2015 09:21 am
by Logan360
Pffft easy +T-ing. That's so retro.
Re: injectors
Posted: 26 Jun 2015 09:25 am
by Logan360
Do it the hard way, like I am
fucking lol. I have always wondered on the 2.3 on the LE jet. Would like to see how it goes
Re: injectors
Posted: 26 Jun 2015 09:44 am
by 360beast
it's the best way to turbo
only people who like staring at cars in pieces for years do something crazy like a twin turbo 16V :p
Re: injectors
Posted: 26 Jun 2015 10:32 am
by Logan360
As with my 965 T6, who's gonna expect that from a 360? Which over here are civic like in nature?
Re: injectors
Posted: 26 Jun 2015 02:02 pm
Not sure what compression you will have, but a turbo engine without turbo will probably be a drop in power.
Re: injectors
Posted: 26 Jun 2015 02:16 pm
by 360beast
Compression is 9:1 but hoping the increase in bore size and 531 head will make up for it.
