I've got a question concerning water pumps for early B19-engined cars with a "fixed fan" (ie no viscous coupling). Pumps for later cars with a viscous fan have a different part no, and my question is whether or not the two pumps are interchangeable.
The parts manual lists the following parts:
463425 Water pump [for fixed fan]
B19A, CH- 810500 (that's 1983 carb-fed 360s and earlier Volvo-engined "S-models")
3283043 Water pump (also 3344253) [viscous fan]
B19E, B19A CH 810501- (all injected B19 360s and carb-fed B19 360s from 1984)
3344252 Water pump [viscous fan]
B200
Fans and pulleys are also different, so I'm assuming that is where the difference is:
Pulley
1276144 B19A, CH- 810500 [for fixed fan]
3283023 B19A CH 810501-, B19E [viscous]
1346447 B200 [viscous]
Fan
3296426 B19A, CH- 810500 [fixed]
3283062 B19A CH 810501-,B19E, B200 [viscous]
Viscous coupling bits B19A CH 810501-,B19E, B200:
3283063 "friction clutch", part 6
3283026 "washer", part 7
Water pump flange screw
955272, part 2 B19A, CH- 810500 [fixed]
946544, part 8 B19A CH 810501-,B19E, B200 [viscous]
Basically, would a later B19 water pump fit my 1982 DLS even if it has the earlier fixed-fan type? Could the bolt pattern be different?
[PS Edited to add B200 part nos]
