Headlight issue
jakz17
Headlight issue
Post by jakz17 »
Hi I have a new problem.
My headlight doesn't work anymore I set the selectors on "2" and nothing happen when i turn off the engine the headlights turn on .. And when I set it to 0 they turn off.
All the fuse are ok
Thanks
Re: Headlight issue
Post by bogbasic »
I would remove the fuse box and clean the connectors underneath - they cause all sorts of unexplainable things to happen. Also is your alternator ok??
jakz17
Re: Headlight issue
Post by jakz17 »
I think the alternator is almost new and I have check the fuse box is ok front and back no strange connector :(
360beast
Re: Headlight issue
Post by 360beast »
Have you checked both fuse boxes?
Re: Headlight issue
Post by bogbasic »
Hello, I would check all the earth connections and any relays that might have been swapped, etc? Have you got a circuit diagram? I didn't know about two fuse boxes, so that's new to me.
jakz17
Re: Headlight issue
Post by jakz17 »
i have check the fusebox in the engine bay i didn't know there was a second ? (or you mean the 2 little plastic boxes near the headlights ?)
I have a circuit diagram but it's pretty hard to read for noobs like me :lol:
How can i test my earth connection? Adding a wire between the "-" and the engine ??
360beast
Re: Headlight issue
Post by 360beast »
Yeah isn't there one in the engine bay and another hid somewhere, can't remember exactly where as I have never needed to know.
Logan will know what I'm on about.
Re: Headlight issue
Post by MCHUDD »
Take your dash clocks out and check the loom conection at the
inside of the bulk head. Thats how i fixed mine.
sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4
Re: Headlight issue
Afaik only the injection models have the auxillary fuse box behind the battery for the fuel pump and fog lights. The main lights use the main fuse box.
There is a bunch of relays on the steering column, not sure if the lights are controlled there, but is another place to check.
jakz17
Re: Headlight issue
Post by jakz17 »
I've check the wire seems to be ok... i really don't know what's the problem i have to check the earth connection.
I also have seen that i don't have to fire the engine when i set the selector on 2 i turn the key and i turn it back my headlight goes on...
Re: Headlight issue
Post by bogbasic »
I was wondering if someone has replaced any of the relays under the dashboard recently, perhaps with the wrong sort i.e. normally-on as opposed to normally-off or vice versa, sorry, I can't remember what the correct sort is, but, I am just thinking this because when I tried to get a new relay from the shops a couple of years ago, I could only get the wrong sort, although they were identical externally, bar the symbol. Its the little black plastic cubic ones, not much bigger than a sugar lump, and they're clipped onto the steering column!!
I would certainly clean all the earth connections - sorry, that was what I meant by checking them.
