B14 4E with bike carbs
Hi, I have a ramp of carb from a gsxf 750 and I am wondering if it could be a good upgrade to remplace my Weber 32DIR. Is there some power increase to hope ?? Thanks and sorry for my English .
Re: B14 4E with bike carbs
More peak power but less useable power as it will all be top end and they require more maintenance and setting them up properly is harder.
It's for a drift car not a daily so top end power is fine and maintenance too. I want to have the most of my 1,4 because i don't want to swap i'm affraid to break the propshaft with a 16v swap. I will keep my 1,4 for practice and change car when i get more experience.
But a couple of HP more could help
What i've done:
- smaller wheel radius ( 175/50/13) soon i plan to use 165/55/13 on the rear
- fully stripped interior, no heater
- maintenance obviously
- bucket seats
What i've plan to do:
- lowering and stiffening suspension
- PU mounts
- hydro e brake ?
Power upgrade:
- Bike carbs ??
- Cylinder Head Porting & Polishing
- Other idea ???
My goal is to reach at least her factory power (70hp) but a 80-90 would be nice.
What i've done:
- bucket seats
- PU mounts
- hydro e brake ?
Power upgrade:
- Bike carbs ??
- Other idea ???
I would go with a single weber 45 DCOE for the carb
Do what porting you can that is effectve and a cam upgrade
I already have the mikuni Bike carb. And do not want to invest too much on the 340 just maintenance stuff and "free" upgrade because i do not trust the propshaft. A weber 45 DCOE isn't cheap
I found someone that did it on a c2j so it's almost the same as a B14 4e:
https://www.youtube.com/watch?v=zvgZ9xPBb20
