Master cylinder
Posted: 16 Sep 2017 11:49 am
by MCHUDD
Hi to all you tech people
This maybe a silly question but is there any other way
other than the master cylinder, that the system can
draw in air?
sm44 sm44 sm44 sm44 sm44 sm44 sm44 sm44
Re: Master cylinder
Posted: 16 Sep 2017 12:32 pm
by 360beast
Wheel cylinder seals leaking, perished brake hoses, rusted through brake pipe, caliper seals perished, seals between m/c and reservoir and the m/c can be rusted through and leaking in to the servo.
Re: Master cylinder
Posted: 13 Oct 2017 12:03 am
Also the fluid can get locked in the resevoir if the seals between the resevoir and master cylinder have flowed into the master cylinder blocking the fluid entry.
Re: Master cylinder
Posted: 13 Oct 2017 12:04 am
On the 360 its can also feel like air if the rear adjuster is not quite working right, mine are still a bit intermittent, even though all clean and assembled correct AFAIK.
Re: Master cylinder
Posted: 14 Oct 2017 03:37 pm
by bogbasic
Ahhh, the good old 360 brake pedal which goes 90 percent to the floor......
Re: Master cylinder
Posted: 14 Oct 2017 09:59 pm
by 360beast
Ride_on wrote:On the 360 its can also feel like air if the rear adjuster is not quite working right, mine are still a bit intermittent, even though all clean and assembled correct AFAIK.
I didn't know this, might be worth taking a look at the adjuster on my 84.
Re: Master cylinder
Posted: 02 Nov 2017 07:39 pm
by bogbasic
Just get on and bleed them, you know it makes all the difference.
