I need a pre 85 brake master cylinder
Posted: 03 Nov 2005 06:44 pm
by Ronnie
Bugger, I bought a classic car...
My master cylinder is shot. Bought a new one listed for years 83-90, but they lied and it doesn't fit. I need one with a little heat shield bolted on it which fits into the older, small diameter vacuum unit.
I can find exactly five thousand post 85 units from friendly neighbourhood outlets like German & Swedish. However, to get an older unit I need to raid a museum in Oslo and spend enough money to buy myself an S80.
Can anyone recommend a source for ancient 300 parts?
All the best
Ronnie
Posted: 03 Nov 2005 06:47 pm
by 5lab
could you convert the whole brake system over to a post-85 unit?
failing that, just look round scrapyards
Posted: 03 Nov 2005 06:57 pm
by Ronnie
Not a bad idea to just fit a later vacuum unit, and bolt in the new master cylinder. But won't know how difficult it will be until I have it all in bits, and by then it might be too late. I'm pushed for time. Scrap yard is probably not a good idea. It's the rubber seals in my M/C that have gone - and scrap ones are likely to be just as bad.
Many thanks for your input anyway!
Posted: 03 Nov 2005 07:01 pm
by daffodil
hi 5lab is right...i have changed the braking system for the later type..it is a straight forward remove replace of the servo and master cylinder
good luck
Posted: 03 Nov 2005 07:33 pm
by Ronnie
Nice one!!!
You guys are the best
Posted: 03 Nov 2005 09:06 pm
by Ronnie
I assume the 340 one is identical to the 360? Does the later vacuum servo unit bolt straight in? Any mods or fudges required? many thanks again people
Posted: 03 Nov 2005 09:32 pm
by 5lab
not sure, look to see if the parts (on eurocarparts etc) suit 340s and 360s as well
Posted: 09 Nov 2005 10:15 pm
by Ronnie
Now sorted. I spent the wonga in the end and sourced a direct replacement part via Volvo (ouch).
It's very nice to now be able to use the brakes for longer than 5 seconds without pumping them! sm43
