Page 1 of 2
340 suspension
Posted: 23 Nov 2005 03:59 pm
by 340cbr
After some playing with my 340 1.7 I've seen that I really need to stiffer the car, it rolls to much..
In the front I'll put new springs and AA bar. What brand of springs do you recommend?
In the back I don't now exactily what to do. Fitting a rear sway bar is possible? And if I put another stiffer road spring above each rear roadspring
I'm interested in lowering the car to...
Sorry for my english it's really bad today, and I don't know If I used the correct technical terms.. I hope that you understand me :oops:
Posted: 23 Nov 2005 05:35 pm
by 340GLT
Well you are at the right place here looking at suspension. Classicswede is a good person to talk to in this subject. He can supply you with poly bushes and lowering springs etc. Also check out 'My bros 5 link setup' in accessories and tuning its awesome!!!
Cheers Adam
Posted: 23 Nov 2005 05:55 pm
by 340cbr
Yeah, i've seen that topic... Awesome transformation!
But I don't think that a car with that tranformation will pass the Inspection here in Portugal :?
I'm looking for some easy efficient tricks
Posted: 23 Nov 2005 09:51 pm
by 340_singh
make some lowering blocks for the rear. Im planning to make like a 50-60mm drop all around. Leaving it on 13" steelies as well.
And im planning to cut of a coil at the front and hope i get an even drop.
Should help i suppose. cheap and effective.
I dnt no how u treat your 340, i treat mine like whatever and dnt really care what happens to it. So i dnt worry about cutting coils etc. But if you want to down a more professional route then get some hardened springs.
Posted: 23 Nov 2005 10:10 pm
I must say I'd never recommend cutting coils from springs - uprated springs from Dai aren't expensive anyway.
Posted: 23 Nov 2005 11:21 pm
I must say cutting spring in good nick is a bad idea cutting old soggy ones is even worse :(
The probblem with doing that is one they will not sit correctly and two you will have a very soggy ride. Every time you go over a bump the suspension will bottom out with a bang :!:
Have a look at the " performance cat " in the offer section.
If you want further info just ask.
Posted: 24 Nov 2005 02:28 am
by 340cbr
Cutting is not very safe...
The car will be used in some track days, and "road nights" :lol: , eheh
classicswede, can you make a description of everything that you have on the performance cat topic, what everything is, where is mounted, and what differences will made?
Because I don't understand some english technical terms :oops:
Maybe I'll be interested in something :roll:
Posted: 24 Nov 2005 10:48 pm
Ok here goes
Rear Spax adjustable dampers-totaly transforms the road holding, allows adjustment for indivdual requirements.
Rear lowering blocks-spacers to lower the rear ride height of the car.
Front lowering coil spring- can be used to lower and stiffen the front end of the car.
Front wishbone bush and tie bar bush(poly)- improves location of the front strut esetial for any performance 300.
Anti roll bar link rod kit- helps the anti roll work( best results would be with an uprated a-r-b
Anti roll bar to body bushes- improves locaton of a-r-b
Poly front engine mounts- helps to save the prop by holding the engine in place(does not transmit vibration through the car)
I'm sure I have missed something but let me know what you think.
Posted: 28 Nov 2005 01:21 pm
by 340cbr
Thanks!
The rear lowering blocks I think that I know someone that can do it for me. I need to take de measures to ask him if can do it. They are alluminium right?
I need some front springs to lower and stiffen it. Maybe I contact you in the future cause I can't get it arround here...
I'd love to get the rear dampers but that's to much money. I have thought in another ways to stiffen the back of the car... maybe another set of rear road springs (stiffer).
The other pieces are very interesting but not for now :mrgreen:
Posted: 28 Nov 2005 11:48 pm
The lowering blocks are alluminium.
Stiffer spring with some good std dampoers would improve thinngs.
Posted: 04 Dec 2005 08:26 pm
by 340cbr
How much do you recommend that I lower the car?
I'm going to install in the car four 400's whells in 14', 185/60 R 14, i think. They are ugly, but i hope that they do a big increase in handling compare to mine 13's.
Posted: 05 Dec 2005 04:53 pm
by 340cbr
It's easy to put a 240 rear sway bar in the 300?
Posted: 05 Dec 2005 06:10 pm
by fidgad
Is it me? :( You lower a car using aluminium blocks? I guess you're right but how does it work? :roll:
Posted: 05 Dec 2005 07:58 pm
You do when you've got rear leaf springs :)
Posted: 05 Dec 2005 09:27 pm
They lift the axle up off the springs= wheels sitting higher in the body.
