Brake upgrade Project (Disks all round) Completed!!
Post by 340GLT »
This is going to be a thread to keep you all updated on my brake upgrade. I will post pics that i have and keep posting until the parts are bolted onto the car!!
To let those of you know who dont already i am using 280mm Vented Golf G60 Rallye Disks on the front with Subaru Impreza calipers.
The back will have solid disks around the same diameter with 2WD cosworth Calipers.
The front setup is nearly done!! The disks are mounted on the hubs and i have refurbed some front struts to allow me to develop this setup off the car. The hubs need to be skimmed on the back then i can make the caliper mounting brackets.
Pics to follow.
Cheers Adam
Sounds exciting. Do you have to tease us with no pics yet?
Post by 340GLT »
Simple fact is i dont have any yet mate i keep leaving the camera at home!!!!
Cheers Adam
shimon340
Post by shimon340 »
heya
what are you doing about a handbrake? rear discs got a small drum inside for handbrake?
thanks for your help 2nite adam, look forward to seeing brake pics here
good luck
shimon
Enjoy your 300s
Post by 340GLT »
2WD cossie calipers dont they use a cable setup through tha caliper and the arm on the caliper is the same/similar to the 300 arm on the drums so problem solved!!!!
Cheers Adam
Post by 340GLT »
Right guys here is what most have been after!!!!
The first pics are of a reconned strut!!!
Here is the complete strut looking very new!!!! :lol:
Here you can see the new platform and the extra thick bead of weld!!!
And here you can see we welded the top side aswell for extra strength!!
Right this is a comparison of the two disks on hubs!! As you can see the standard one is a dwarf compared to the G60 ones!!!
This is a close up of the new disks!!
Here you can see the extra holes drilled in the disk!!
And this is a comparison of the two calipers!! As you can see the twin pot design of the impreza ones are much larger!!
And here is a mock up of the complete setup!! As you can see its not true as there is no bracket for caliper yet!!!
What you reckon guys?
Cheers Adam
Carl
Post by Carl »
NICE!!!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
Dude! Nice one! Erm, no wanting to put a cat among the pigeons (and I havn't actually checked..) but I'm sure there was a rumour a lil while ago that Corrado G60's bolted straight on, maybe they would have not needed drilling??? Though I can't see golf and corrados being a different PCD.
Right then, so how much you selling set's for then ;)
Post by 340GLT »
No mate the wheel PCD is the same but the hub doesnt use those. it use like a PCD of 96 i think not 100mm. Oh and the disks are the same disks as the Corrado ones!!!
Cheers Adam
SoLaMaNdA
Post by SoLaMaNdA »
Very interesting! :D
Put me down for a set of these when you're done. :D
Post by 340GLT »
foggyjames wrote:Put me down for a set of these when you're done. :D
Who says i'm going into production? :wink: Might leave it ultra rare limited edition of 1 pieces!!!! lol
Cheers Adam
Post by 340GLT »
For those of you seriously interested i can work out a price its costing me!! It ent cheap for a recon kit for the front calipers alone its £30 a side!!! I am buying bits as and when but if you are interested i will do some prices of the complete setup inc calipers!!
Cheers Adam
Post by petefarrell360 »
That is looking very good indeed Adam. Good work that man! So many upgrades going on at the moment, it's all good for 300 modding.
Post by 340GLT »
Well i finally got round to machining the hubs down today!!! Look looovely!!!! If you look at the pics of the hub centre you can see the fresh metal that i machined down to, i have skimmed 4.5mm off the back off these to allow clearance for the caliper carrier.
Cheers Adam
