Slightly random problem this one. I suspect this is a simple tune-up issue (for a start, my plug leads are ancient, and new ones are going to be ordered next time I'm making a shopping trip to the stealership), but the limited 'window' of water temperature it happens in has got me wondering...
Basically, after the car has been running for 5-10 minutes, it suddenly won't idle. Lift the revs to 1500-2000 and it'll keep running, but sounds like it's running on two pots. Depending on the type of motoring, it'll go away usually within 2 minutes. If you're in traffic, that's a major PITA.
Apart from the leads (which are known to be shot), the carbs could do with a rebuild, and the sealing to the manifold is 'dubious' at best. However, vacuum leaks wouldn't particularly explain the limited timescale (unless the manifold expands in a manner which only affects it at certain temps....shrug...). If I had the wideband installed, that would help me on that front...
Ring any bells? I'm fairly sure it's entirely due to the leads, but I just thought I'd throw it open to the floor...
