whats the P.C.D. of a 340/360?
bennett
Post by bennett »
what wheels can i fit whats the PCD? THANKS.
340 Nate
Post by 340 Nate »
hi there! the pcd is 4x100, can fit a fair few wheels from different cars like volkswagens & bmw's for example, found this site which is pretty handy time to time http://www.carlsalter.com/wheel_fitments.html
Nate
Post by redline »
full spec is
pcd 4 x 100 offset 32...38 centre bore 52.0
you can use rims with a bigger cantre bore ( if its a lot bigger use spigots to fill the gap) and I have heard you can fit rims with a snaller centre bore if you use spacers as deep as the hub flange ( ie the rim sits over the flange as it obviously wont fit on it )
bennett
Post by bennett »
thanks boys got just the rite set of rims here.
