Any way. Before I began my service I started the car. The idling had been getting progressively worse before I went home for Christmas and when I started it up again today I couldn't get it to idle at all. It keeps running with my foot on the throttle, but sounds rather like a helicopter (I wonder if it's missing a cylinder).
I then changed the following (it's a 1983 (Mk.II) 340 GL auto):
-Air filter ( & tightened up carb bolts - and the three screws that secure the top of the carb to the main carb body, these were very loose). I also managed to snap off the top of the bolt that secures the lid of the air filter housing to the body.
-Condenser, points, rotor arm and distributor cap. The only problem was that I couldn't use the new contact point as it was the wrong shape and no matter how I moved it, it wouldn't line up with the breaker arm (which was identical to the old one). I don't think Volvo do these parts any more, so I have to make do with what I can find at motor factors. GSF and Eurocarparts don't do them either.
-Plugs and leads. I gapped the plugs at 0.8mm.
I need some ramps before I can change the oil.
I started the car and it idled exactly as it did before. I tried to drive it after warming it up a bit, but I can't get it into gear very successfully and then it stalls very easily. When I try to engage D or R I get a noise that is exactly the same as if you tried to put a manual into gear without depressing the clutch.
At one point, I thought I heard a noise like some escaping air. Is this likely to indicate some sort of a vacuum problem?
Thanks for your help
Ed
