Seen on eBay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... RK:MEWA:IT
Anyone know what kind of data this gives? Or if it allows you to adjust things?
It's been going round and round for weeks now - I'm tempted to buy it...
Blue-Point LE/LE2 Jetronic Checkit
Pimp. This sounds like it's up Andy's street...I'll email it to him.
He knows about them
They've been around for the last year or two, they come and go, usually go for around £35-50.
Yeah, and they're also normally a bit more "singing and dancing" than that one appears to be.
The LE-Jet really is only a simple analogue EFI system, no EEPROMs or processors to reprogramme, just a whole load of resistors and capacitors to control everything.
If you could work out which of the hundred resistors did what, then you could adjust things, but otherwise that's the way it is. Some adjustments can be made by playing with the spring settings in the flappy air mass meter but its crude.
The breakout box is just a way of checking the various signals and outputs form the thing, it can't adjust anything.
