unleade or not unleaded
Post by redline »
received this email today from a total stranger , whats the answer guys
Hello I have just bought a 1985 Volvo 340GL with 45,000 genuine miles. Please can you tell me can I use unleaded petrol or should I mix it with red x.
Many thanks Linda
d3k4y0
Post by d3k4y0 »
I think this discussion's been had before somewhere... I'll have a look
edit: here we go
360GL wrote:All 300 series petrol engines without catalytic converter from including 1987 model year onward can use either leaded or unleaded fuel. The octane rating requirements are:
B14.4E, B172K, B200K: min. 96 RON leaded, min. 95 RON unleaded
B14.4E-D, B172K-D: min. 95 RON unleaded only
B200E without cat. converter: min. 92 RON leaded, min. 91 RON unleaded
B200E with cat. converter, B200F: min. 91 RON unleaded only
Early models must use leaded fuel (or lead supplement additive):
B14 models: min. 96 RON
B172, B19A, B19E, B200K, B200E models: min. 98 RON
source: Haynes Manual, User Manual
Janitor wrote:most people use a "fuel cat"-this converts unleaded back to 4star !!
they go inline with your pipe/hose!!
http://www.fuelcat.co.uk/mainpage.html
I'd say that's a no, unless it's got a fuel cat in it
antiekeradio
Post by antiekeradio »
the required RON number has nothing to do with leaded/unleaded
the kat versions did not have any changes to the engines (valve seats etc), and they are unleaded _only_
so if the RON is 96 or higher, no problem if its unleaded!
(the 'fuel kat' ghyzmo looks like a genuine example of 95% marketing and 5% luck... what a BS :shock: )
Depends on the engine.. that 340 could well be a 1.7 which afaik all can run on Unleaded.
I doubt any problems will arise from running it on unleaded - our 1982 345's were always run on unleaded without any trouble.
n xntrx volvo
Post by n xntrx volvo »
scam
go to t-bricks if you wanna learn about getting a car like mine
http://forums.turbobricks.com/index.php?referrerid=3007
98 s70
88 780
87 240 16vt 2.5L
I got the email too. Hugh always ran on 95 unleaded, so I guess that's just fine. If it eats the valve seats, just pull a late-model head...
shimon340
Post by shimon340 »
there is a mistake in haynes guys...
Al 340s with the B144E engine can use unleaded. So thats X reg onwards...
You need to change the ignition timing on the pre-Renix cars.
For Renix 340s you need to ground the B pin to allow the car to run on unleaded....
Enjoy your 300s
This is one thing that winds me up with the amazon bigade. They "THINK" this fuel cat is what is allowing them to run on unleaded with no problems - the funny thing is they run spot on with std unleaded-no treatment.
All these fuel cats do is increase octane which is fine if high compression is the issue. If valve guide or seat wear is the problem a fuel cat will do bugger all for you. The best bet IF the engine needs 4star fuel is to use an approved additive such as castrol valve master.
shimon340 wrote:For Renix 340s you need to ground the B pin to allow the car to run on unleaded....
I actually saw an official Volvo 'pin grounding kit' on a scrapper the other week - dead impressed!
Erm, yeah, but on some engine's like mine, its a compression issue and you need the high octane (mine's a pre 1987 B200E)
There's good info on the Volvo Car UK website.
ebdl
Post by ebdl »
X reg onwards are not all B14.4E - mine's an '83/A and has a B14.2E. I suppose I should probably be using an additive... hmm.
Andy's-Old-Beast
Post by Andy's-Old-Beast »
Yeah, using leaded never really occurred to me, the previous owner said she always ran it on unleaded, but should I be using an additive? Now I'm confused... :?
Mine's an '86 B200K.
[EDIT] D'oh! No it's not, it's an '89! Not sure what I was thinking then, I had a bit of a brain error. sm75
So it's probably ok then... sorry about that! :lol:
Previous owner of The Beast!
Now a 1969 Dodge Monaco 5.2 V8 :D
An 86 B200K in an 89 car?
Andy's-Old-Beast
(see edit above)
Go on, you cover those tracks :-D Yeah, 89MY is well and truly 95 octane lame-spec :(
