Posts: 3657 Joined: 31 Mar 2005 09:01 pm
Post
by 340GLT » 02 Feb 2006 10:35 pm
Looking gud mate and a load neater than the old setup!!! Amazing what you can do with fairly readily available parts!!!!
Cheers Adam
Posts: 5471 Joined: 25 Apr 2005 06:52 pm
Post
by classicswede » 02 Feb 2006 10:41 pm
It fits quite well. With the gas mixer on the intake hose just squeezes in
( I can see these is going to be a little rubbibg problem).
The throttle cable is off a machanical injection 240, the linkage just needs a little mod to make it hold, the peddle end is spot on.
Posts: 9361 Joined: 29 Jan 2004 04:20 am
Post
by foggyjames » 03 Feb 2006 12:47 am
Excellent
Glad to see you got it working AOK.
Have fun with that centre bolt?
Post
by classicswede » 03 Feb 2006 08:34 pm
That centre nut went on a doddle. There is a special small 8mm nut that is used. I just used a 8mm socket and on it went.
I had a problem with not not willing to idle below 1500rpm. After loads of messing about I worked out the TPS switch was holding it open.
If anyone wants to use the manifold with the std zorst then remember to blank of the bolt holes where the inlet manifold used to bolt on - or it will blow!
The main things I need to is remove the old throttle cable, re route the inlet pipes and filter and make up the spare wheel bracket.
I hope it does improve fuel consumption as its been costing a fortune in fuel!!!!!
340cbr
Posts: 501 Joined: 31 Oct 2005 12:50 pm
Post
by 340cbr » 03 Feb 2006 10:18 pm
Tlaking about manifolds... Does anyone knows if the 440 1.8i inlet manifold goes in the 1721cc?
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
Post
by foggyjames » 03 Feb 2006 10:28 pm
The SPI manifold? I don't see why not...
340cbr
Post
by 340cbr » 04 Feb 2006 01:56 am
hum... "SPI"?
Post
by foggyjames » 04 Feb 2006 02:05 am
Single point injection
The B18U, right?
Post
by classicswede » 04 Feb 2006 01:26 pm
The sinple point manfold and throttle will not fit as it is too tall. I've already looked at that one - its a no go.
The later multi point manifold point into the bulkhead so would need modding.
antiekeradio
Posts: 697 Joined: 04 Jan 2004 10:53 am
Post
by antiekeradio » 04 Feb 2006 07:52 pm
what engine type does the depicted manifold/throttle body come from??
340cbr
Post
by 340cbr » 04 Feb 2006 11:26 pm
Yes B18U...
Well.. If it fits I will look for one, has it seems like a carb model... And probably I can't legalize the injection model here in Portugal...
But if it don't fits.. never mind
Post
by foggyjames » 05 Feb 2006 11:47 am
antiekeradio wrote: what engine type does the depicted manifold/throttle body come from??
Early 1.7 injection I think.
Post
by classicswede » 05 Feb 2006 11:53 am
Yes the manifold was only ever fitted to very early mpi 4series. I think some similar age renaults may have also had the manifold.
Chesh740R
Posts: 159 Joined: 16 Aug 2004 06:23 pm
Post
by Chesh740R » 05 Feb 2006 07:17 pm
The B18 E Engine had those Manifolds, about 1987-88 maybe 89 ish.
Both my F Reg 480's had the B18E which was the most Powerfull 1.7 Injection there was at 110bhp irrc.
