Basically, in the last week or so (mainly since I fitted a new starter, but I reckon that conincidence) Fake has been not wanting to startl when warm. Everytime, look at the plugs, and they are black, so cleaned, and off we go. Andy said to check dizzy, which I'd been putting off as it's the 1.7, but after two screws and the heater fan off, easy job. Corroded to anything, so cleaned the arm, and the contacts, and all is well.
Anyway, couple of days later, does it again (some how cleaning dizzys never works for long) so new dizzy, check plugs, and they are now orangey, not black, on the ceramic bits, and black on the electrodes. Ok, new plugs with new dizzy cap and arm.
Today... 20 miles later. Won't start. Electrodes black. Still. Not chuffed. Left tools at home thinking I'd sorted the problem.
Luckily, have socket set, and find piece of cardboard to get soot off plugs.
Ok, here is what I reckon:
*Earth lead not making good contact, I'm going to sort that with some heat and solder now.
*Choke cable not adjusted proper, I'll try and sort that, but see below
*Fake has the replacement weber carb. I can't find a mixture screw on it, it has an idle, but I can't see what would be a co2. Turns out the one I thought was, doesn't change naff all.
Now, cos this is a weber, there is nothing about it in the haynes or russek manuals, so I'm going to try doing the choke cable as per the solex setup, and hope. I'm also going to check to see if it's the same as the 1.4 one, as that doesn't have a co2 adjust either. There are also 2 wires cable tied up next to the carb, I'm guess idle solanoid and something? Didn't check, was a quick look to see, but blue/red or blue yellow I think.
Any better ideas guys on what else it could be or how to set up the weber?
(sorry my problem posts always go on for ever, but I try and put what may be useful, even thought half of it probably isn't
