suspension
Posted: 28 Apr 2006 01:37 am
by VOLVO 340 (84)
hi again iam sorry for asking alot
can i know the best suspension in the front and rear which make the car more stable and comfortable on the road
thnx in advance
Posted: 30 Apr 2006 01:37 pm
by IvanAE86
For comfort+stability I would go with Koni dampers all around and a whiteline anti-roll bar I think... For more sports use also buy some lowering springs.
Posted: 30 Apr 2006 11:16 pm
by girlracer
My car i have spax shocks on the back, lowering blocks and special front lowering springs, polyeutharane bushes on the suspension combined with low wide profile tyres so it handles really well!
Ask anyone who has experienced a ride in my car!
Posted: 01 May 2006 07:56 am
by Raod
I look for a replacement of shocks for my 360 GLT (B200E) and can't find koni or bilteins for this model. I only find Monroe (discarded), Boge and KYB Excel-g. What do you think about this options? Do you know any web site where I could buy shocks/springs online at good price?
Thanks in advance and sorry for my bad english. :oops:
Posted: 01 May 2006 07:03 pm
If they're easy to find over there, pick up a set of Volvo OEM ones. On a car of this age you'll normally see a massive improvement in performance by using original spec parts which aren't worn out.
Those will usually be the best compromise between comfort and performance. If you decide you want more performance at the cost of comfort, you can possibly track down a set of used adjustable Koni shocks (which I think can be rebuilt, if they're worn). As mentioned, Spax shocks all round are on the way.
Posted: 01 May 2006 07:35 pm
by Raod
Anyone can told me the reference numbers of the koni shocks for my 360? Will work with stock springs?
Thanks in advance.
Posted: 01 May 2006 07:53 pm
Yes, they work with stock springs. I know a couple of people with full sets, so I'll make enquiries.
Posted: 07 May 2006 05:40 pm
by Raod
Someone could tell me if I forget a good option of shocks for my 360 GLT? I wan't to buy online if possible.
I want give to the car a "sport feeling" I have a koni shocks+springs in other car and love the way it works. 8)
Thanks in advance.
Posted: 12 May 2006 05:48 pm
by Raod
Finally I choose a complete set of kayaba excel-g as a compromise solution for the use that I give to the car. The car really needs a new suspension and I order these set to a local dealer (200 € 4 shocks).
What I should buy to do the work(washers, top rubber)? Should I remove the balljoint of the steering arm to remove the front shock? How? Any tip?
This is the first time I 'll do this job, before that I only change the oil, brake pads, spark plugs... simple things. It's a difficult task?
Thanks in advance and sorry for my english. :oops:
Posted: 12 May 2006 07:51 pm
by IvanAE86
It's not that difficult if the front shocks are not stock anymore..
You need to take out the entire strut (preferably) so you will need to loosen the steering balljoint. Here's what you need to do:
Detach the stabiliser (undo the nuts on the little metal bars that are fixed to the struts), and pull the little rods out of the way.
the balljoint is easy to remove if you have a steering knuckle remover, if you dont have special tools, use 2 hammers. First undo the nut on the steering knuckle to the point where it is level with the top of the threads. Now use one big hammer to support the underside of the ring that the thread goes through, and hit the top of the nut with a rubber hammer.. Or else put some piece of wood or something in between to make sure you dont damage the nut. If you give it a few hard hits it usually comes loose. This is necessary because the fit is conical, and needs a bit of an impact to shake loose (or constant force applied by the special remover tool).
With that out of the way the rest is easy.. you can loosen the balljoint on the bottom of the strut by removing the bolts on the little bracket with which it is attached to the control arm. Then undo the 3 nuts holding the top of the strutmount in place and you can take out the entire strut assembly..
From there on you need some spring tensioners so you can remove the spring without hurting yourself.
If the original shock is in there you need to hold it upside down so the oil can drain out. the old standard shock didnt want to come out on my car so I reattached the strut to the car on one point and started pulling like an idiot...this worked but I'm sure there must be a better way to get it out..
Posted: 12 May 2006 09:11 pm
by jtbo
Rotating shock when pulling helped in my case.
Posted: 12 May 2006 11:00 pm
by Raod
Thanks for the info. I receive the shocks the next week, once installed I'll post the result. :wink:
Posted: 23 May 2006 11:24 am
by Raod
The rear shocks are on the car!!! this weekend hope I could install the front and post some photos.
Thanks. :wink:
