Page 1 of 2
How to adjust Solex 28-34 Z10
Posted: 09 Jul 2006 07:23 pm
by rumcays
Hi guys!
Yestererday i failed exhaust emission MOT test, the result of CO level was 5.43%. I was told that this could be cased by wrong adjustement of carburettor. Could anyone step-by step explain to me what the shown screws are for and haw can I properly adjust it?
It's very urgent case becouse tomorrow I'll have to retest my Volvo.
Thanks ! :wink:
Posted: 09 Jul 2006 10:07 pm
by jtbo
Here is arrowed idle adjustment, mixture adjustment is at carb base, right side when looking this image, there is just hole and screw is at bottom of hole.
Here is the hole with mixture adjustment screw at bottom left, facing almost to camera.
Oh yes, this is 34-34 Z11, but I guess it should be similar?
Posted: 09 Jul 2006 10:16 pm
by shimon340
hi there!
my dad 340 failed it MOT for the same reason. Ive heard these solox units for the 1.7 can be hard to adjust - in that you cant get the CO low enough. There is a post here somewhere that comments that float can sometimes need changing - they are plastic and absorb petrol and loose their buyancy. Wouter ( from holland ) posted it. He suggests getting a new one from renault.
i'll try to find it for you...
all the best
Shimon
Posted: 09 Jul 2006 10:19 pm
by 340cbr
The mixture adjustment screw is in the place that is pointed in the last picture
The idle screw is in the top of the carb. In the first picture there are 2 jets and one screw. Is that one.
To adjust it, first adjust the idle to 900rpm.
Then you kick the acelerator and adjust the misture screw until when you kick the acelerator (to arround 3000 rpm), when the revs come down it stops in the 900rpm. The better way is to adjust it until it goes little below 900 rpm and then come to 900.
My english is not vey good but I thinck that you understand what I'm trying to explain
Posted: 09 Jul 2006 10:51 pm
by MJ
I can understand it anyway :)
So if the revs fall low, and then rise back up to 900 (say when pressing the clutch during driving) the carb may need adjusting? Oh dear...
Posted: 10 Jul 2006 02:07 am
by 340cbr
If it isn't much and he is running ok don't worry. These carbs don't like being adjusted many times
But you can make a little adjust in the mixture screw.
That's what i've learned with a 440 Gl and now with the 340 1.7 :?
Posted: 10 Jul 2006 11:55 am
by MJ
I'll leave well alone, it only just had a 12 month service and MOT so it should be good :)
Posted: 10 Jul 2006 12:48 pm
by 340cbr
If it runs OK leave it alone :wink:
Posted: 10 Jul 2006 02:19 pm
by rumcays
I'm afraid in Z10 there's no mixture screw in that place. I was looking carefully for that little bastard but i couldn't find it. Indeed the idle jet seems to be the lower one showed on my first picture (is it the same?). What jtbo's showed on his first picture is idle speed adjustment screw and it's responsible only for dosing fuel not for mixing it with the air. So that's why I'm a bit confused and still looking for solution :wink:
Posted: 10 Jul 2006 07:37 pm
by pettaw
the idle speed is adjusted on the top of the air cleaner through the hole, you'll need a long screwdriver.
The mixture screw is as in that picture, in the baseplate of the carb, pointing towards the front of the car.
TBH its in the Haynes or any carb book, can you not bung your MOT tester a few notes and just get him to twiddle it down a touch, once the equipment's attached it only takes 2 minutes.
Posted: 11 Jul 2006 11:17 am
Is that definately a solex guys? Looks much like my Weber, I know the weber was there to replace the solex, so it will look similar... but that looks identical top down. I'd be tempted to ask the guy as Andy said, at least it'll be on a gas machine, even if you twidle the screw.
Posted: 11 Jul 2006 01:35 pm
by 340cbr
Tha mixture screw in the weber is in a differente plase.
The idle one is in the same place
Posted: 11 Jul 2006 02:28 pm
Thats what I mean... which could be why the original posting dude can't find it... :lol: We've only seen the top of his carb.
If it is a weber replacement, mixture screw is in a weird 90degree elbow thats moulded onto the passenger wing side of the main carb body.
Posted: 11 Jul 2006 04:07 pm
by mac
If it is a Solex Z10 it's not like any I've seen before - the top of the venturis are all wrong and the single acc.pump jet nozzle enters the primary throat above the atomiser bar, etc., etc.
It looks awfully like a Weber 32DRT or similar (the aftermarket replacement for the Solex 28-34 Z10 CISAC). (saw a few over the years when pelicans tried to claim parts warranty on them).
don't know much about them except the baseplates seem just as prone to warping as the Solex.
Mac.
Posted: 11 Jul 2006 05:53 pm
by rumcays
mac wrote:It looks awfully like a Weber 32DRT or similar (the aftermarket replacement for the Solex 28-34 Z10 CISAC).
As it turned out it's some kind of Weber carburettor, Solex had to be replaced by that one long time ago.
I've taken the carburettor symbol from owner's manual so ... sorry my fault :oops:
Yup I've found the mixture screw (hidden into that elbow case).
Thanks a lot anyway :wink:
