Exhaust dismantling
Raod
Exhaust dismantling
Post by Raod »
Hello.
I've tried to separate the first and central track of my 360 exhaust and it becomes impossible to me. Do you now any tip to get one off the other? I don't have a torch to heat the second track...
Thanks for all and sorry for my english.
Volvo 360 GLT
990
Post by 990 »
Undo all of the exhaust system and lightly twist the section off - unless like me it was unusable then a big hammer also works (and is usually faster) :D
Volvo 360 -- Small Car - BIG Ideas
E990 UBA Volvo 360GL - Vanised
D133 OBU Volvo 340GL - Died
F330 FWB Volvo 360GLT - She Runs :)
GJ53 GPF Volvo S60 - Daily
You'll probably need to give it a bit of heat with a torch first if its really rusted on tbh, then once its hot spray WD-40 into it, be careful cos there'll be a LOT of smoke as the WD-40 goes on:) Don't overheat it too much though cos when you put the WD-40 on it might go on fire, 30-60 secs gentle heating will be plenty.
Raod
Post by Raod »
I'll try to do the job this monday cos today I don't have a torch and the hammer seems to be not sufficient for release the rust.
Thanks a lot. :wink:
Volvo 360 GLT
Join the club...I've been having a nightmare with mine! Heat is the answer.
antiekeradio
Post by antiekeradio »
release exhaust clamps and take it for a ride. engine heat + vibrations will do the job for you.
remember to leave the suspension rubbers in place otherwise the exhaust may fall off the car :o
I've not had a clamp on my mid-pipe to backbox join for about 18 months now...and it's no more loose :D
Raod
Post by Raod »
Hello again.
Finally today I'd a torch for a while and in five minutes the job was done. My 360 has recovered his sound.
Thanks for the posts. :wink:
Volvo 360 GLT
