The stored map differs from model to model and from year to year in some cases. The label on the ECU will give the code number that distinguishes the map. It is the 3 digit code in the second line of the label - not the larger 6 digit Renix part no.
B13.4E (1989 onwards) = 402 (was this ever available?)
B14.3E = 401 (not in UK)
B14.4E = 402 (from 1985 has change up indicator)
B14.4E = 412 (1987ish on) Retarded by 4 deg. to run on unleaded.
B14.4S (not UK) = 402
B172K (1985-1986)= 410
B172K (post 87) = 415
B19A = 404
B200E (1985-1986)= 405 or 408 (408 has engine speed limiter)
B200E (post 87) = 411
B200EA (Nordic market) = 441
B200F = 411
B200K (1985-1986) = 406 or 407 (from 1985 has change up indicator) (407 has speed limiter.)
B200K (post 87 ) = 414
Mac and Pettaw.
[This is for reference only so I reckon its better if its locked and any questions can be posted in a seperate topic
