on the 1986 GL...what is its compression ratio? did not find any info yet...
p.s have bought the car recently...
													B200K 499962 and camshaft question
						camshaft and pistons
have not looked yet which letter marked is its camshaft. is there any possibility to avoid interference by replacing the camshaft or are the pistons the bad boys?
						Re: camshaft and pistons
Your cam should be an Y-cam, one step below A, try find a V-cam or K.mgarageu wrote:have not looked yet which letter marked is its camshaft. is there any possibility to avoid interference by replacing the camshaft or are the pistons the bad boys?
Personally I would go for a V-cam on the 2liter engine.
Piston noise when cold is normal in B200. B2x0 series engines are so called "low friction engines", some changes were made compared to B19,B21,B23 series engines to lower the fuel consumption etc.. but those changes weren't as good for the structural strength as they were for economy..
