Steering rack
Steering rack
Post by filthyjohn »
Is there any unforseen, silly reason why a non-PAS rack won't bolt straight in place of my PAS one? Mine whines and creaks, and it's had a couple of hard knocks, so I thought I'd replace it, after which it'd be free with all ancillaries to anyone who wants it.
I've decided I want manual steering because I assume it's less work to put in, and since I'm not a wussy single mother, I have no need for its puny power assistance :P
Plus it'll save about 0.75Bhp :lol:
Cheers for any help.
No reason, you'll need the lower half of the steering column too though. The exhaust downpipe for a PAS is different, but will work fine with a non-PAS car.
Cheers, that's what I thought. That was another reason, more space for exhaust routing if a turbo was to politely approach my car, introduce itself and buy it a drink.
If anyone is interested there is a recon power rack of ebay
jimf671
Post by jimf671 »
And the power rack has a different ratio. If you have the right tyres (and have increased overall offset, and maybe reduced castor) the power rack, without the power, is a way of getting quicker steering with plenty of feel.
The man makes a good point...and loves to bump old threads! There's quite a big difference in overall handling feel thanks to the 'quicker' rack.
A M R
Post by A M R »
hmmm might have to have this off you when i get my glt...
or is it possible to buy this anywhere else?
not so sure that a PAS rack without pressure in it would perform the same as a non-PAS rack, just because all the valving etc is still there, and IMO would make it feel weird.
Agreed on the gearing though, PAS has almost a turn less lock to lock with the same steering movement.
Caster is the same on PAS and non-PAS cars, cos the PAS system was really an afterthought, rather than designed into the entire suspension system.
The yanks who remove PAS from 240s the lazy way loop a hose between the two point which usually have hoses connected which 'leave the area' (to the reservoir and from the pump, respectively). It supposedly works... :?
antiekeradio
Post by antiekeradio »
yep, all you do in that case is transfer the fluid from one side of the piston to the other. same effect as a hole in the piston.
jimf671
Post by jimf671 »
The bypass hose is the usual way of dealing with this. I havent actual seen one on a 360 but most seem to work ok this way. As long as there is something in there to lubricate it and no hydraulic lock it should work.
