Dont put the konis on the hardest setting what ever you do! Start them in no more than half way position - This is VERY improtant.
The easy way to stiffen the front springs (as shipping will cost you a lot) is to use 360 springs cut down - they are probably stiffer than the diesel ones.
classicswede wrote:Dont put the konis on the hardest setting what ever you do! Start them in no more than half way position - This is VERY improtant.
Konis for the front are very hard to find.
Why shouldm't I put them on the hardest setup?
They are not new
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
If the konis are any good set to full they will make the car very skitty on the back and also make the rear wheels slide. Set to an intermediate position they should make the car very poitive and hold the road very well.
classicswede wrote:If the konis are any good set to full they will make the car very skitty on the back and also make the rear wheels slide. Set to an intermediate position they should make the car very poitive and hold the road very well.
that's what i want
I'm pretty sure Ali still has his (used) Konis on the stiffest setting on the rear of his 360 - not sure what it's like in the wet, but I'm sure he said it really wasn't atall that bad and you still had to try to get it to slide...
I happen to think they make the car fun to drive, and my rears are at full -1 turn. It will slide very easily in the rain, but I also found it to be really easy to correct with a bit of countersteering (as opposed to my ae86, which will bite your head off if the slide catches you off guard).
Havent had much problems with it otherwise.. slides reasonably well in the dry too. Lucky for me it grips well with the fat 13x8's + slicks on trackdays.
Yeah mine are set to full, not a clue what they're like at any other setting as I installed them like that and never looked back lol, they do make it fairly stiff but theres still grip there in the wet even with a welded diff, just have to make sure your aware of it and not drive like an idiot
