which springs fit the frnt of a 360?
- volvo360gle/340turbo
i herd on this forum ford escort srings fit! is this true? wud they cope with the weight of the 2liter engine? i dnt want to start cuting springs! but i wud like the front to be dropped and stiffend by at least an inch!
Cheers, Andrew!
Cheers, Andrew!
1988 360 gle
1990 340 gl (turbo conversion)
1991 340 LE 1.4 (29000 miles on the clock)
I can get springs made for the 300's. What ride height are you looking for? What use is the car being put to?
im looking for something for fast road use something jst to stiffn it up a bit! i would like to lower the car by 1 inch! Wat price would u be talking to get them made? and can u send them to northern ireland?
andrew
andrew
1988 360 gle
Spring prices are £50 a pair for simple spec ones like this.
1" lowering is not a problem. Poundage I can work out as well. What model and engine is it for?
If you want 1" lower than your car is sitting now I will need you to measeure the ride hight.
I can sent them to Northern Ireland no probs.
The height is measured from the wheel centre to the edge of the wheel arch.
If you measure from the ground the size of wheel and tyre would give different readings.
No probs just let me know when you are ready.
Glad you got them. Did they turn up on monday?
Drop me an email and let me know - I've had a few problems with late deliverys recently.
