distributor part number
nzvolvo360
Post by nzvolvo360 »
Can anyone tell me the part number for my missing distributor. I believe the engine is a 200 series (1986 model) and therefore should have a bosch distributor?
The distributor sits under a water pipe and exhaust manifold at the front of the engine. Engine number is 1326775.
Thanks
Sorry I don't recognize the part number or the position you gave us, the distributor for a B200 in the 300s sits at the front of the engine block, near the inlet manifold, but anyway the Volvo part number for the whole distributor is 1356781.
If as I suspect, you're only after the cap and rotor, then the part number for the cap is 243797 and the rotor is 1367052.
These are Volvo part numbers though and may well not help if you're getting your parts from a factor, you'll just have to trust their part numbers....hope that helps.
