Carrying heavy loads - stiffen up the rear?
SoLaMaNdA
Post by SoLaMaNdA »
Double meaning in the title aside :lol: .....
What is the easiest way to beef up the spring rate on the back of a 360 for carrying heavy loads? Is it simply cutting the springs off a scrap car, loosening the bolts on each side and sliding on an extra length of leaf spring?
I'm sure a drifter has done a modification similar, (with lowering).
Hugh's done it... but then again, would you want to copy it :P
I've read about the 360 cup guys using leaf spring assistors, don't know much about the, but they are supposed to be designed for towing use.
SoLaMaNdA
Post by SoLaMaNdA »
I've seen a device you can fit to coil overs for towing, not much use on a 360 :cry:
5lab
Post by 5lab »
my method works well?
yeah slip another spring in, underneath, then add a locating bolt. andy's got a drillbit ;)
http://www.springassisters.co.uk/Leaf%2 ... 20Page.htm
Dunno if these would be of any use?
If you are only loading the car up with a resonable amount of weight then a pair of spax adjustables will do the job. If you are stuffing loads of weight in the back and/or towing then you have three choices 1) add part of another spring in (down side is without any load you will have a very hard ride and imo is not a very good way of doing it) 2) coil over dampers (down side minimum spring rate I can get in 80lbs iwich is a bit ott without any weight in the back - advantage is you can adjust to the amount of weight you have) 3) is uprated rear springs I am going to ge getting some made as the rear is a bit soft partly due to the constant weight of the fuel and tanks.
SoLaMaNdA
Post by SoLaMaNdA »
The load level is abit less than this for much of my driving, (70kg on the tow bar + 3-4 people).
Have you thought of putting the bikes on the front to even the load out :lol:
No on a seriouse note just a set of spax would probably solve the worst of the problems tbh. When you are loaded up you could turn them up a bit stiffer to help. Lowering the front end would also help a little.
Idealy uprated rear springs are the answer. I'm not going to be doing mine for a few weeks (or reslisticly 2 months) but if you want to wait I could price up for having another set made.
To give you an idea of how much difference the spax have made I had to tup a 1" lowering block in to give the same ride height as it was with the originals.
Post by redline »
classicswede wrote:Have you thought of putting the bikes on the front to even the load out :lol:
Not very practical lol
but what about roof mounted bike racks so l the weight is spread over both axles and not just over the rear end
5lab wrote:my method works well?
Just winding you up mate ;)
Dai, how adjustable are the spax, how do you change them when they are fitted?
The Volvo accessory method was a coilover which went in place of the standard shock. Cheeky...if you could make it work...
Chris_C wrote:how do you change them when they are fitted?
Theres an adjuster at the bottom of the shock that you can turn with a screwdriver from what it looks like...
volvorsport
Post by volvorsport »
well if you want to make a coil over on the std shock , need to check your local gas/water piper stockists .
some motorbike springs would suit .
i have to say robin hood used to modify dampers like this , and they were totally and utterly useless for the job intended , i still think if you did the job properly would be a good idea .
SoLaMaNdA
Post by SoLaMaNdA »
I'll see how bad it is, not used the tow bar yet but as you can see from that photo, the bikes make a difference!
No way am I trusting a roof rack with our bikes :shock:
