b14.4e fuel filter
dynamite40
b14.4e fuel filter
Post by dynamite40 »
hi guy's quick question my fuel filter between the pump and carb
if i leave the car for a day the filter is empty and a cow to start
why is the fuel draining cant't see no leaks
is there a one way valve in it to stop the fuel going back too the tank
thanks
If fuel hoses are original they look ok, but are really leaking, this is at least my experience from 1988 360.
dynamite40
jtbo wrote:If fuel hoses are original they look ok, but are really leaking, this is at least my experience from 1988 360.
thanks will have a good look at that
antiekeradio
Post by antiekeradio »
the one-way valves are in the fuel pump. more often than not these have started to leak because of old age.
also, i believe there is a return line on this model (fixed jet in fuel pump which keeps steady fuel flow around the pump, meant to exclude tendency of vapour lock)
Most likely to be the fuel hoses leaking and drawing air. Particularly the cloth covered fuel hoses. The worst bit of cost cutting ever. Change all those first, everything, right from the carburettor backwards to either side of the plastic fuel lines at the fuel pump and tank end.
That works in about 90% of cases, the other 10% is fuel pump.
dynamite40
thanks
thanks guys will try some new pipes and fillter on monday not had chance yet been busy
will let you know what happens
once again thanks
I think I will get new fuel pump too as with new hoses carb still gets dry over night or then I just install electric pump as I happen to have one on self.
