which car had most torque
Which of these cars has the most torque
Volvo 360 gl
3
60%
Volvo 360 glt
0
No votes
Volvo 360 gli
1
20%
Volvo 340 gl
1
20%
volvo 340 gle 1.7
0
No votes
Total votes: 5
5lab
Post by 5lab »
answer away chaps :) talking about non-cat mk3 cars.
360GL
Post by 360GL »
B200K: 160 Nm at 3000 rpm
B200E: 159 Nm at 4200 rpm
87 360GL B200K
5lab
Post by 5lab »
damn, i know that, i was hoping everyone else got it wrong cos it surprised me :P
Duvel78
Website Admin
Post by Duvel78 »
I'm trying to collect information about the differences between a 360 GLT and a 360 GL injection. Everything is welcome! 5lab, you said something one day about the fuel consumption (lower for the GLi), can you find the numbers again?
V3M for life!
5lab
Post by 5lab »
i'll have a look tonight
incidentally, someone blabbered that the final drives are different, this is NOT the case - all i can suggest is maybe the fatter tyres make fuel economy worse?
Fuse
Post by Fuse »
I would have answered GL also. Although I didn't remembered nm-figures but the B200K has a Y- or L-cam which are much more low torque cams than A-cam with B200E which is much more rpm-cam. B200K also has higher compression ratio than B200E.
Janitor
Post by Janitor »
whats that in lbft ? for us oldies :mrgreen: and is that at wheels or flywheel?
Azurael
Post by Azurael »
Ooh... The one with an implanted RB26DETT! Just because it wouldn't fit :roll: At least that's my bet. I want a Volvo 345 GT-R V-Spec :D
OHK 578V - '80 345DL B14, 46,000m
Duvel78
Website Admin
Post by Duvel78 »
5lab wrote:i'll have a look tonight
Yeah I've heard sooo many things about the "possible" differences between the 360 GLT and GL injection... I don't believe there are any differences mechanically (for example between the final drives), the power is the same between my GLi and my ex GLT, same reactions on the road.
Thanks if you can find some info about that.
I'm convinced there's only a difference for the equipment but not mechanically.
V3M for life!
5lab
Post by 5lab »
suspension is different isnt it?
Duvel78
Website Admin
Post by Duvel78 »
I'm REALLY not sure about that...
Probably yes for one "detail", gas shock absorbers on the GLT for the rear wheels and "normal" oil shock aborbers for the 360 GLi, that's a fact.
Except that, it's the same from my point of view.
I've heard that the front wheel-axle unit SHOULD be different but I don't believe that and I need concrete elements to prove that.
V3M for life!
Fuse
Post by Fuse »
Azurael wrote:Ooh... The one with an implanted RB26DETT! Just because it wouldn't fit :roll: At least that's my bet. I want a Volvo 345 GT-R V-Spec :D
Nah.. You don't need a Nissan engine for those HP's. ;) Volvo Redblock with 16V top and turbo big enough will give same power figures. 8)
http://www.300power.com/medlemmar/stange/bild36.jpg
http://www.300power.com/medlemmar/stange/bild63.jpg
http://www.300power.com/medlemmar/stange/bild68.jpg
(That car is sick btw... :D I have a vid of that thing beating an Eclipse, a Vette etc... on a strip. Crazy Swedes... :P They are taking over 1000hp from redblocks there... Not street machines usually though but still impressive. Though there are couple over 600hp 240's with redblocks street legal there.)
