Page 1 of 2
b18ft & 300 series gearbox
Posted: 06 Mar 2007 08:28 pm
by monkeyismycopilot
Hello,
I happen to have a b18ft engine from the 480 and I would like to know if the manual or automatic gearbox from a 300 series bolts onto the b18ft engine.
kind regards
Posted: 06 Mar 2007 09:40 pm
by 340cbr
The garbox on the 300 series are on the back.
What needs to match the bolts is the "clutch house" (I do not know the name in english), and yes it fits perfectly
Posted: 06 Mar 2007 09:53 pm
so the gearbox is mounted in the rear. Can anyone please provide a picture of this setup? thank you.
Posted: 06 Mar 2007 10:07 pm
I found these pictures which answer my question but now i'm left wondering how long the whole engine/gearbox setup is.
hmmmm anyone?
Posted: 06 Mar 2007 10:25 pm
by germ
Hi
and welcome
first of all what are you thinking of doing?
swaping engines? or somthing compleatly different?
will
Posted: 07 Mar 2007 08:37 am
Hello,
Fitting to a triumph spitfire.
that's the gear but if it 'would' fit???
Posted: 07 Mar 2007 10:22 am
by Nick C
I'm pretty sure it wouldn't, there would be no room for the Box. It'd have to go in the tunnel pretty much between the seats, and that is far too narrow. The Spit box sits between your legs IIRC (and is a pain to get to...) and is bolted to the back of the engine in traditional fashion. (I do however know someone who has put a 2L 16v Sprint engine in one :twisted: )
Posted: 07 Mar 2007 02:05 pm
by germ
monkeyismycopilot wrote:Hello,
:o :o :o :o :o :o :o :o :shock: :shock: :shock: :shock:
dont think its posible but anything is possible i guess with money and skill in which case you would be better off doing somthing much stronger and powerfull.
Posted: 07 Mar 2007 03:49 pm
Thanks guys,
So the gearbox is bolted direct to the diff?
let me get this right
Engine(clutch)==prop==gearbox/diff
Posted: 07 Mar 2007 03:59 pm
monkeyismycopilot wrote:So the gearbox is bolted direct to the diff?
Yep, it's a transaxle design
monkeyismycopilot wrote:Engine(clutch)==prop==gearbox/diff
Correct
Posted: 07 Mar 2007 09:24 pm
by petefarrell360
Sounds like an interesting project. Here's a good picture from a 300 brochure from 1989 of a 360 GLT.
It shows the layout that makes the 300 a well balanced car.
Posted: 07 Mar 2007 10:18 pm
Now that's a good picture!
My first idea was to supercharge the engine in the spitty but hmmm I'm not keen on that as the engines are not that great.
Now the b18ft with a rich mod ecu is around 170bhp.
I should also add that I'm not after buying a 300 to just strip the poor thing and throw it away. I'd rather source from scrap yard or a seller on here/ebay.
My b18ft is complete minus the head/turbo. I have a complete loom etc etc.
Posted: 07 Mar 2007 11:37 pm
by Nick C
What's wrong with the Spit engine? The 1.3 is generally regarded as being bulletproof! The 1.5 slightly less so due to the 3-bearing crank, but still fairly reliable. Interesting article on them: http://www.jyclassics.co.uk/article1.htm
Chuck a 6-pot in there :twisted:
Posted: 08 Mar 2007 12:25 pm
Hi Nick,
I'm only going on what I read on the spitfire forum. There is a guy who supercharged his 1500cc lump using a mini SC unit.
that's working still. I understand the 1300cc is revvy and the 1500 has the torque (spittys) I did read about the 3 bearing crank.
Posted: 08 Mar 2007 09:07 pm
by germ
my dad had 2 spitfires 69 and 73
both 1.3
his first was a 6speed 90hp 1.3 that weighed under 700kg (specialy tuned)
his second was a 5 speed 70hp
Now they are hardly slow cars :P
the 1.5 was crap and less powerfull made for us market very sad :(
will
