Unidentified lumpy bit and rubber pipe
REDDUSTER
Post by REDDUSTER »
Their is a unit, off-side positioned between the fuse-box, expansion tank and air filter that comprises 2 cylindrical units joining a rectangular central block which has rubber pipes sprouting from it. 2 are attached to clear plastic pipes that meander off towards the rear of the car but the one at the front just hangs limply down by the water tanks not attached to anything.
Any idea what it is and if this pipe should connect to something? Doesn't stop the car from running.
Also is green garden twine the correct method of attachment that keeps this unit strapped to the component underneath? I've heard of value engineering but this seems extreme, or is it advanced sustainability?
Charles
:wink:
Nick C
Post by Nick C »
No idea what it is, but garden twine should never be used on a car. Use cable ties instead. It's tradition ;)
Fuse
Post by Fuse »
A pic would be helpful. :P
Sounds like the magic CVT valve, but as above, pic would be best!
dynamite40
yep
Post by dynamite40 »
Chris_C wrote:Sounds like the magic CVT valve, but as above, pic would be best!
i also think its that
