Car idles rather ok, I did need to rise idle a bit as after running minute or bit less idle speed seem to decrease, when I push throttle a bit it will pick up to normal again, this is not big issue.
Other thing however is bit bigger issue, when car idles and kick loud pedal to half way quite hastly it sputs and revs drop to 100 or so and engine turns very difficultly, if I pump throttle it can pick up again.
When I rise rpm to around 2000 very gently pushing pedal and kick loud pedal half way again it does the very same thing.
If car idles and I slowly apply throttle, around similar speed as normally accelerating in city car sputters and backfires, again if I pump throttle a bit it picks up rpm and around 3000 or more it seem to be running fine again or at least sputters less.
Perhaps this is caused because I do have wrong emulsion tube in 1st throat place, there is two of second throat emulsion tubes installed at the moment, I will swap that tomorrow so perhaps issue goes away, however I don't remember there being such issue at late summer/early autumn when car did run last time.
Also shouldn't that make it to run just quite rich?
Well, we see what happens tomorrow if there is no rain.
I did check oil and all looked to be okay, but after piston slap (I have quite bit of this) started to go away as engine did warm there was this thunk thunk thunk, which is imo crankshaft bearings, there was oil pressure as light was not lit and that did go away after engine was completely warm, don't know how hard that can be until need to worry but it was bit like gently tapping block with hammer, but sound was more soft like crankshaft bearing do sound.
225 000 km driven, can't need new lump yet or someone has fiddled my car's odometer before I got it
