How To Get More Power
Josh_Cohen
Hi There I Need More Power From My 1.7 340 any tips
New User Long Time Lover Of Volvo 300's
Josh_Cohen
Is It Easy
Is it a mamoth task or pretty easy and do u know anyone with one also if i was to do that do u know anyone who would want to buy my engine it's only done 57000 and a full service history i was also thinking saab 2.3 turbo
Josh_Cohen
Re
so anywhere u can think of that i can get a renault 19 16v engine also there fuel injected arn't they u'll need the ecu aswell
And convert the tank so it's baffled so the high pressure pump doesn't run dry, and uprate the fuel lines, unless you want to convert to carbs. It's a straight swap in that the block bolts in, doesn't mean its an afternoons work.
I'm currently dropping a turbo lump in mine, you'll learn a lot from it. I believe the OP's question was however how does he get more power from the stock engine
Firstly, is it running well now? You'll find a well serviced engine will offer more of a power change than a K&N ever will.
That on stock injection system with wiring it in? I'm impressed if it is. How much longer does it take to get the knowledge to have a clue how to do it
Josh_Cohen
yeah
it runs ok but as i haven't passed my test yet i can't drive it so it's stuck in a garage at the mo when i bought it the guy at the garage said it would go 2.5 miles and then cut out so i took the fuel sender out and took the stupid little filter off cut the pipe at a 45 degree angle and blew the pipe out and it ran better than it did but don't know if it's solved it but i have a spare carb for it anyway
In which case, will an insurance company take you with an engine swap having only just passed your test? Something else to think about, I'm now 23 and can insure the turbo easy enough.
Tbh, to get to learn driving, a stock 1.7 running well will do you fine, I compete in rallies in one. It's 85bhp/ton when running well.
Thats what I was meaning! How easy is the 16V loom? And are you running carbs, or did you convert the fuel to high pressure spec?bennett wrote: took a few months of reading and a sized engine to work it out.
stealthstylz
