sorry for not being around much. In process of sorting a house, things are nicely quieter now.
My gold 340 47,000 miles has been in storage for 4 months. Unfortunately I didnt get a chance to start it up from time to time. I know thats not good.
I tried to start it about 3 weeks ago, it turned over on the starter but the bettery was running low. upon trying to restart it just made a loud clunking sound and repeated this when move the ignition off then back to on. Thinking the starter was jammed as it hadnt had enough current to move forward and connect fast enough - thought it had jammed in the flywheel. Jump starting simply repeated the clunk noise and switched all vehicle electrics off even when released from sprung position 3 to 2. reset by switching completely on and off. Engine could not be turned at all by moving the crank pulley - even with a socket suggesting a seized engine (unlikely - Ive started engine stored for longer ) or a starter jammed in the flywheel
I waited for a free sunday to pull the starter. before doing so, I tried a good recharged battery.
turning the ignition and "clunk". then off and on and the engine turned!! took a while to start as the fuel lines were empty but eventually it did.
exhaust was quite blue and smokey. engine had what seemed like a little piston slap (at what reg did volvo introduce dual metal pistons which eliminated piston slap on the B14?? ). revving slightly just produced more blue smoke.
pulling the plugs shows cylinder 1 (near flywheel) was textbook beige.
cylinder 2 had white deposits on the plug top (pic to follow)
cylinder 3 had oil fouled plug
cylinder 4 was slightly sooty.
the plugs were volvo own but looked rather tired.
I dont think the oil is from the piston rings given the mileage (47,000) and that the engine was so good when in use.
The piston slap was concerned though.
A valve stem seal is possible but from reading B14 green book it sounds like only the B14.0 had stem seals - at least the manual says "if applicable" for valve seals and comments that only the B14.0 can be machined to fit stem seals - unless this was a way to fit later seals to the first engine type?
can only confirm if all the B14 have stem seals. There must be some sort of valve stem seal? any info guys??
any other ideas whats going on with the oil from the exhaust? I dont mind pulling the head of the engine etc but only if really needed.
I havent started it since as Im not sure to run it to burn off the oil or am I risking more damage.
I'll need to check oil levels before and after starting too to get an idea of consumption....
look forward to hearing from you
S
