my 340 stutters during cornering!!!!!
massey
Post by massey »
can any one help me..... my car stutters when i go in to a corner to fast on the power!! like the ignition is being cut or the fuel!! but it dose it in to both left and right corners!!! not fun at all!
sideways is better
What type of engine is it? Its probably the fuel sloshing about in the carb float chamber. its worth checking the float level just in case it isn't right.
massey
Post by massey »
sorry didnt say did i its a 1.7 340 gl
any idea what the float hights should be!!!
sideways is better
33.7mm, with the float chamber lid turned upside down with the floats resting hard on the ballbearing. If you measure with the ball bearing spring unsprung :? (you'll see what I mean when you do it) then its approx 37mm.
