Page 1 of 2
Wheel nuts
Posted: 23 Apr 2007 10:40 pm
by Roop
Right, stupid noob question #1:
What size are the wheel nuts on the 360 supposed to be?
The wheel wrench which came with the car was stored inside a pair of piss soaked jeans in the boot and has gone horribly rusty, so I've been trying to use a 20mm socket to undo the wheel nuts, but it sometimes slips and is starting to round off the heads. It's not a flat sided socket, so this could be the problem, but I just thought I'd check that the nuts aren't a weird size before I go and buy a new socket.
Cheers.
Posted: 23 Apr 2007 10:47 pm
by jarlidge
hi
i think they are 19mm
Posted: 23 Apr 2007 10:55 pm
by Roop
Yeh, a 19mm socket would fit, but we had to really beat it on and it seemed to make a mess of the nut.
Posted: 23 Apr 2007 11:01 pm
by Nick C
It should be 19, the problem you're having is probably down to damaging the heads with the 20! Go to your local Halfords and buy one of their extending wheelbraces, they are fantastic (and they use a standard 1/2" drive for when you lose the supplied sockets/ get an imperial car...)
Posted: 23 Apr 2007 11:16 pm
by Roop
Thanks chaps. I've always found a six inch ratchet handle and an old aluminium table leg make a good substitute for a wheel brace, but I'll check out the Halfords one.
I'm going to get my hands on some new nuts tomorrow (oh-er!) as I lost a few during an ill fated "I wonder if rusty old Vauxhall rims will fit without spigot rings" experiment.
Posted: 23 Apr 2007 11:43 pm
by A M R
is dai still making alloy wheel nuts?
Posted: 25 Apr 2007 07:32 pm
by mickt
I have had an adventure with the wheelnuts on my 84 360
As I had a puncture I proceeded to remove the wheel nuts using YES my Halfords wheel brace But discovered the rust had enlarged the size of the nut to about 20mm so I had to call out the RAC to use a powered spanner to remove it
Don't want to get anyone worried the rust only occurs on the older type wheel nuts with a chrome cap over the top for a good finish as in MK1 cars with no hub cap fitted I never had this problem with my other 300 series cars with a good 19mm biter of a wheel nut
cheers mickt
Posted: 26 Apr 2007 09:44 pm
From what I know they are all 19mm (Mickt the porblem with the nuts swelling to 20mm is common on all the alloy coated nut as fitted to 300's and 200's). The aearly production (Mk2/Mk3) steel wheel cars had a very std short nut that was then changed to a long nut.
I do have new nuts available that are dome nuts to keep moisture out.
Posted: 26 Apr 2007 10:05 pm
by A M R
how much you charging for a set of 12 dai?
i need to get 4 locking nuts as well for my rimsies. where can i get them?
Posted: 04 May 2007 05:48 pm
Anyone know what the thread is on 300 series studs?
Posted: 06 May 2007 11:28 am
The new nuts are £2 each
Posted: 06 May 2007 12:34 pm
Is £2 a thread size Dai?
What exactly are the nuts you're offering? OEM nuts? All-steel? I'd like something that's not going to crap-up, really.
Posted: 06 May 2007 01:52 pm
by germ
classicswede wrote:From what I know they are all 19mm (Mickt the porblem with the nuts swelling to 20mm is common on all the alloy coated nut as fitted to 300's and 200's). The aearly production (Mk2/Mk3) steel wheel cars had a very std short nut that was then changed to a long nut.
Posted: 06 May 2007 04:25 pm
by stealthstylz
He means the actual thread size not the nut size.
Matt
Posted: 06 May 2007 05:02 pm
by 340GLT
Its the same as an impreza is it by any chance M14??
