Turbo engine conversion?
Posted: 04 May 2007 12:31 am
by Steve_mk2
hi really new to volvos hoping to pick up a nice cheap one and stick in an engine that will give a lil more power... have seen 1800 16v but im thinking turbo, i just love turbo cars, is there a well known conversion for these cars? if anyone has ideas i need help... a whole lota help lol
thanx steve_mk2
Posted: 04 May 2007 11:37 am
by Frits
Take a look around, its done before..
Posted: 04 May 2007 11:53 am
by germ
heheh ^ mk1 turbo for a quick example 1.4
1.7turbo
why not 1.8 16v turbo? < ive seen 300hp with quite low boost on these
2.0 turbo
2.3turbo
and i guess theres more but imo turbo is cheating
will
Posted: 04 May 2007 11:55 am
by germ
forgot to say it depends which 300 you have
340 1.4 to 1.4 turbo
340 1.7 to 16v 1.7 turbo
360 2.0 bolt a turbo on and 2.3 turbo
Posted: 04 May 2007 11:58 am
340 any to Renault any
The one I'm putting a 1.7T into was a 1.4, everything is the same, just need a couple more donor parts.
I was tempted to 16V the turbo, but it's not as easy as it initially looks, still something I'm keen for in the future, but the 8V first makes a lot more sense.
Posted: 04 May 2007 12:03 pm
by stealthstylz
Renault F7 turbos are rubbish without throwing a lot of money at em. Can get about 210bhp with a low boost turbo setup on a F7R and they're very unreliable keeping the headgaskets together is very hard.
To run more boost you need new rods & pistons which is just over a grand.
Just fit a B230 turbo can see a lot more power a lot easier.
Matt
Posted: 04 May 2007 02:03 pm
by Frits
And don't forget one thing, a turbo conversion is not cheap. I does'nt have to be expensive, but without money you won't get anywhere.
Yeah, I was thinking of doing it the other way, 8V 480 engine, with a 16V head. Just there is more to it than I first thought
Posted: 04 May 2007 02:42 pm
by Frits
I wonder, don't you have that way exactly the same engine than the standaard 16v?
However, there are options enough. But the easiest way to make a 300 fast is to take a 360, and put in a N/A 2.3 That almost fit's directly, and is possibel in one day.
Posted: 04 May 2007 06:13 pm
by Steve_mk2
ok so volvo already make a turbo engine that would bolt in? what engine and car are best suited? really only interested in turbo engines also do volvos run airflow meter or is it read from manifold ie cossie?
Posted: 05 May 2007 02:52 am
360s are your best shell donor....injection models (mainly GLTs) are best as they already have an electric fuel pump.
The turbo lump comes from a 7/900 - available in 2.0 or 2.3. Both are essentially the same unit as the standard 360 engine. There's conversion info all over the board. Very little needs doing.
The factory management systems for the B200/B230 turbos were Bosch Motronic (airflow flappy paddle crap) for earlier cars (up to 89) and Bosch LH-Jetronic 2.4 (hot-wire air mass metering) for later cars (up to 98 ). The LH2.4 loom appears to be best pulled from a late 240 - look for models with a hot-wire AMM. I have one from a 940 awaiting surgery, but it includes almost all of the wiring for the whole damn car! 240 ones appear to be pretty much stand-alone. You'll also need the matching flywheel.
Posted: 05 May 2007 04:29 am
by Steve_mk2
thanx for all the info, seem like it defently worth the time. i mean i ain't looking for this to be a proper fast car just want sumin different and sumin that will light up the rear wheels (sideways is the best way!) plus not many peeps will expect a 360 to be pushin them up the road chattering lol
any one else got more info would be greatly apreceated (sorry for spellin) hopefully i'll get on the case soon and come to a meet see sum of you guys are from my way. i'll be the one d**kin around and around and around lol
THANX AGAIN STEVE_MK2
Posted: 05 May 2007 04:42 pm
by jtbo
Also there is soon one 2.5L 16 valve turbo when SJS gets it done
