engine mounting bolts
Vart
Post by Vart »
am i just incapable or is the engine mounting bolt by the downpipe on a b14 a different size or just bitter? similarly the clutch cable seems a tricky task to remove on the engine end.
i don't have a great deal of underaccess to the car, as far as i can reach with it on the ground really.
any hints or tips appreciated
A M R
Post by A M R »
stick one side of it under the pavement and then you will have more room under neath :wink:
failing that, just go to halfords and get some ramps/axle stands. theyre not much...
Vart
Post by Vart »
the car has no prop and the nearest pavement is a busy A road. a long tow.
ramps and stands for removing an engine from a donar car is an expensive way to go. a guess a hack saw might work though. i'd rather not mind.
Stands are what... £20 tops? You'll always find a use for them in the future too...
Halfords stands are a tenner, I got a second pair over Easter as I needed both Kar and Fake up in the air (typically one decided to break as the engine is half out the other :()
The B14's mounts should be all the same size, and the clutch cable is a biatch. As I didn't need mine any more I cut through the clutch cable with a big pair of pliers, just so I could get on with the job. Engine mount is a pig to get to, I had my set of deep six sided sockets and a 2ft breaker bar to do the job though.
Good luck mate
Vart
Post by Vart »
axle stands obtained. i'll see how it goes later when its cooled down a fraction. i'll probably end up cutting the clutch cable if it gives any more jip.
cheers for info
