But I could do with a diesel ( cos im a cheapskate
Diesel
- garethreece
Diesel
I miss my Volvo!!!
) and was wondering what sort of diesel engines go straight into the volvo and what sort of cost would be involved?
B980EAV '85 340 GL
SMO58Y '83 360 GLS
VK06FKP '06 Suzuki Swift 1.5 5dr
N62NTG '96 Ford Mondeo 1.8TD
And only 2 of them are on the road
SMO58Y '83 360 GLS
- trabitom99
AFAIK the Renault 1.6 diesel engine in the 340 was the same one fitted to the diesel versions of the R5, R9, R11, Express/Rapid.
You might get a bit more help on that in the French forum, they're a bit more used to diesels
Pete has a Nissan Turbo Diesel engine of some sort in a rusty old 360 shell. It was some sort of partial conversion that was abandoned after the engine was fitted.
Anyway yeah Volvo did do a 1.6 diesel. It was a diesel version of the 1.7 Renualt engine. Low tech, and very reliable.....Only trouble is its slower than a barge being pulled by a moped. 0-60 was about a minute I think. Also they weren't available in the UK, although possibly a few may have crept over from Ireland where they were available.
- trabitom99
+1pettaw wrote:Only trouble is its slower than a barge being pulled by a moped.
It was the slowest 300 ever made, and IIRC the fuel consumption at motorway speeds is hardly better than a 1.4 petrol at double the noise level.
I could post a couple of tech spechs out of a brochure at home if you're (still) interested ...
germ
fuel consuption should be over 60mpg and thats pedal to the floor
and once you get going its fine
when i was in bordeux the other day i got a ride in one i guess 0-60 in a minute is about right
nah its a bit better than that.
would do 140km/h ok but its boring 1 million times worse than the r5 diesel and thats very boring
id go for a r19 turbo diesel engine i think its possible and it would shift nicly
Will
Will
Volvo 340
1988
1988- garethreece
Hmm, I think that the standard diesel is out of the running then! The performance of the 106 is bad enough!
The biggest problem is a gearbox to work with it, I suppose I could just try overhauling the 1.4 petrol to try and get better than the 20mpg it had when i stopped using it!
B980EAV '85 340 GL
SMO58Y '83 360 GLS
SMO58Y '83 360 GLS
- trabitom99
I've got a Mk2 340 Diesel brochure at home. Problem is:
1) it's in German
2) my scanner's in a box in the attic
It wouldn't be a problem typing up some of the technical stuff, the marketing blurb isn't that interesting anyway ...
1) it's in German
- garethreece
Some of the tech stuff would be brill if you could get it mate.
I miss my old tank but the go-kart i drive at the moment does 40mpg even if you drive the tyres off it (and 60+ if you dont
That one of the reasons i stopped driving the 340, the 20-25mpg i was getting out of it was emptying the back a bit quick
. That and it would need some work to get throught the MOT, might just bite the fuel bullet and get a 360, might as well have some performance for my sub 30mpg
B980EAV '85 340 GL
SMO58Y '83 360 GLS
SMO58Y '83 360 GLS
I had a 340 1.6 Diesel
0 to 100 in 20 seconds, top speed was not bad, it can make 155 km/h quite easily and with tima and space, more than 160.
Consumption was great! In some trips I get 4l/100km !
the sound of the engine inside is awfull, but it is fun to drive.
I'm searching for another one to buy
By the way, they can be fitted with the 1.9D from Renault or the 1.9 Turbo Diesel from 440 TD
The first one is damn easy swap!
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
- trabitom99
OK, here goes:
340 DL Diesel 1985 5 speed
D16
1585 cm³
54 PS / 4800 U/min
9,35 m turning circle (same as 1.7 & 360)
Vmax 140 kph
0-100kph 20,0s
Fuel consumption l/100kms (town / 90kph / 120kph)
7,0 / 4,7 / 7,4
Just to compare:
340 DL Petrol 1986 5 speed
B14.4S
1397 cm³
68/5400
9,20 m turning circle
Vmax 160 kph
0-100kph 15,0s
10,1 / 5,3 / 7,5
Sounds like a 1.9 conversion's a good idea unless you do lots of town driving ...
D16
1585 cm³
54 PS / 4800 U/min
Vmax 140 kph
0-100kph 20,0s
7,0 / 4,7 / 7,4
Just to compare:
B14.4S
1397 cm³
68/5400
Vmax 160 kph
0-100kph 15,0s
10,1 / 5,3 / 7,5
- trabitom99
... and that's what the thing looks like:
There, that was quicker than getting the scanner out
