Troubleshooting
Posted: 19 Oct 2004 12:00 pm
My B200E is acting up in several ways so i'll give a rundown of what its doing, what i've done so far(with results) and next things to be done.
1- Starting for the first time of a morning, it cranks over, but sits around 100-200 rpm and carries on, this doesnt improve with time, and it stall when ANY accelerator is applied. when started within 5 minutes it does the same thing.
2- When the engine is started but still cold, it runs like it should and is very racey. When the engine begins to warm however there is a rapid loss of performance, the powerband up to 3000rpm is almost halved, and above 3000 through to redline it is almost flat. To add insult to the injury there are random flatspots in the powerband, more noticable above 3000rpm, and more noticable with wide open throttle. The final problem is the occasional presence of backfiring when at low(2000) rpm and moderate throttle (50+%) is applied.
* Problem persists when different batches of fuel are used of same octane.
* Fuel economy is normal
* Spark Plugs were replaced that resulted in a slightly smoother running. This was mainly because the old plugs were old over the place with their gapping, some more than double the gap size of others. Also of the old plugs 3 were slightly oily, the other was slightly carbon coated.
* Air filter (which looked like it had never been changed) was replaced with no change
* 2 Exhaust leaks were fixed but the backfiring is still there, no change
The Oil and Oil filter are to be changed when this rain stops for more than 5 minutes with the injectors to be serviced/replaced after that. Will also check the replacement spark plugs when rain stops. The other immediate thing will be running a batch of higher octane fuel. Also when i get the cyl head off the other engine it'll be overhauled and put onto this (Thats a while away though).
Thats what its doing, and what i've done to try to fix it. Any ideas?
